hmm. But for testing I just copied and renamed existing .def.jsons without changing anything. And those also didn't Show up.
anyways i tried your method with the help->definitions Folder.
I found this Definition on the official cura site, so it shouldn't be corrupted. The other one is the CR10Mini that I gave another Name, also in the json itself.
But again, after a Restart I searched through all the available non Network Printers and Nothing showed up.
ahoeben 1,986
There is no such list in Cura, so there must be another reason why your definition is not showing up. Your cura.log may show the error. As a sidenote. a better place to put custom definitions is in the configuration folder (Help -> Show configuration folder -> definitions).
