6 hours ago, GregValiant said:The engraved letters must come very close to the top of the model.
What is the height of the model?
What is the dimension from the bottom of the model to the top of the engraved area?
What is your layer height and what is the initial layer height?
If you could post the STL file that would be good.
No, the encraved letters are not close to the top of model.
Model height is ca 70mm and error spot is at 47mm.
Engraved text depth is 0.2mm.
Print layer hights are 0.2mm.
Unfortunately I cannot upload stl file.
Anyway I solved the problem by modifing the model but it seems to be slicing error by Cura.
GregValiant 1,489
