GregValiant 1,489
Another one that types faster than me...
The USB side of Cura isn't supported by Ultimaker anymore. None of their printers require it so it's legacy software at this point. If the side of Cura that is busy sending Gcode doesn't allow for interruption then you will need to try Pronterface/Printrun or maybe Octoprint. Pronterface allows you to see the responses from the printer as well as send codes. You can also write your own macro scripts and send them to the printer.
Smithy 1,146
I don't have an answer for your specific question, but printing over USB is old and not recommended, so just use the SD card and you are much safer. The functionality is included in Cura for some backward compatibility, but AFAIK not actively developed anymore.
