Dim3nsioneer 528
That logo is usually only seen at startup. Does your printer boot until you get the main menu?
You need to reset all printer settings - something did not initialize properly after the firmware upgrade. If your printer does not come up to the main menu (give it 15-20 minutes please), switch it off, disconnect the material station bus cable and switch it on again so it starts as a standalone S5. Then you can do the reset.
krknopp 0
I'm seeing the same thing, I think. I saw it last night 2x when trying to start a print and needing to swap filament in the material station. Screen stuck at "Ultimaker" both times.
