2nd layer larger than others
vision3D
Posted · 2nd layer larger than others
Hello,
My print had elephant foot and I tried to figure it out.
It seems the root cause is the generated gcode, when I open it with Cura the second layer is obviously larger than others.
I'm using the default parameters for ender 3 pro printer, the following should affect only the first layer if Im right.
Initial Layer Line width : 100%
Initial Layer Horizontal Expansion :  0
Initial Layer Flow :  100%
I tried 2 differents stl files https://www.thingiverse.com/thing:1278865 or https://www.youmagine.com/designs/10mm-cube and two Cura version 4.7.0 and 4.6.2.
Any thoughts would be appreciated.
