1 hour ago, ahoeben said:Do you have multiple displays?
I do... and I have had them on all other versions of Cura, is there something different now?
Open %APPDATA%\cura\4.7\cura.cfg in a texteditor (eg notepad).
In the [general] section, remove the lines starting with window_left and window_right
Save the file and try starting Cura again.
If that worked, go into the General preferences and uncheck the option to "Restore window position on start".
On 9/5/2020 at 8:52 AM, ahoeben said:Open %APPDATA%\cura\4.7\cura.cfg in a texteditor (eg notepad).
Thank you ! That worked and solved the problem for me :)
On 9/5/2020 at 7:52 AM, ahoeben said:Open %APPDATA%\cura\4.7\cura.cfg in a texteditor (eg notepad).
Easy - Worked for me also, thanks..
On 9/5/2020 at 3:52 PM, ahoeben said:Open %APPDATA%\cura\4.7\cura.cfg in a texteditor (eg notepad).
Many thanks to Ahoeben!!
It also works for Prusa Slicer!
%APPDATA%\PrusaSlicer\PrusaSlicer.ini
Delete the line start like this: window ~~~~ : 0000; 0000; 0000; 0000; 0000
It is somehow comforting to know that PrusaSlicer is also not without its issues.
ahoeben 1,965
