Hi there.
I was wondering a bit about this, so I'm writing to you.
It doesn't cause problems in 4.6.1, but it does in 4.7, right?
In this part alone, it seems to be the effect of a change on the program side, not the slice settings.
I think I need sigwx's configuration (project file) to confirm the problem.
Why is this not printed as a solid wall?
Hello!
I've attached the project file that generates the slicing I'm seeing. I'm using the 4.7.0 release, not the beta so maybe that matters. Your project slices correctly for me, so its probably a setting that is being misinterpreted/interpreted differently/new interpretation from 4.6 to 4.7 in my project.
GregValiant 1,330
I sliced your model (4.7beta) and it looked fine. Here's the project file.
beeThing.3mf
