2 hours ago, Labern said:Normally you can if its gone bad if it hisses and crackles when it prints or if the roll looks quite yellow . I have had one roll that's was bad from new but generally it should be good.
Does it have a lot of attractions On the parts that are not printing well?
Does the glass plate have the warning sticker facing up?
It does seem a little yellow is that not normal?
Im sorry I’m not quite sure what you mean by attractions. It doesn’t have trouble sticking to the other filament but I’m rarely able to see that cause issues come up in the first couple layers.
Yes the warning sticker is facing up in this print but I have run it upside down before. Is there a difference? If there is I should probably stop doing that.
Thank you so much for your reply.
Labern 763
Does it have a lot of retractions On the parts that are not printing well?
