Bed leveling looks good, so I think that's not the reason.
clean your glass and apply some glue stick and distribute it with a wet tissue to get a thin layer of glue.
Check out also this video:
Thank you so much.
Thank you so much.
Smithy 757
It is normal warping and can be solved with a good/better bed adhesion.
Try glue stick or something else, not every hair spray is useful for 3D printing. Another reason could be that the distance nozzle - bed is too big. Try to level a little bit closer to the bed.
Post a picture from the bottom of you object, then we can see more.
