17 minutes ago, gr5 said:Or I think you can just uncheck "jerk control" and "acceleration control".
I had to check "jerk control" - it was hidden and unchecked. So maybe this default configuration in Cura uses some poor default in the firmware.
Groover75 1
While waiting for my post to be approved it looks like I might have found the solution. It seems the default travel jerk setting in Cura is too high for an Ender 3 Pro. I've reduced it to 10mm/s and everything so far is much smoother.
gr5 2,094
