3 hours ago, gr5 said:Did you save the gcode files? You can get the settings out of the gcode files as well. If there are some still on your printer or hard drive somewhere then you can recover settings from those. There are a few ways.
Personally I just open the gcode file in an editor and jump to the bottom of the file. There are a few lines at the bottom that say what profile you used and what settings overrides you used. At first glance it looks like gibberish but if you take a deep breath and calm down and read it slowly it's actually quite easy to understand. You can also import the settings from the gcode file into cura - I think it's in the "file" menu. Or maybe there's a plugin. I forget.
Even better, if you saved project files, those you can just open and it loads everything.
I will go back into the g code files and look at them
nallath 1,124
You can create a backup by going to extensions - > backups.
On the new machine you can just restore the backup.
gr5 2,225
Bink_Industries 0
Not sure im understanding? I can not launch my old cura as it has no operating system right now.
