Hi Carla, thanks for that. Sorry, I'm only seeing this there now. I posted this queastion on the FB Ultimkaer Owners group at the same time. Erin Oliver got back to me, to say to turn off any plugin-ins. I had a post-process gcode script plugin active to display the line height on the LCD. Once I turned this off, it printed just as before. 🙂
- 1
Carla_Birch 116
If it’s working in a old version of Cura still, but then you get the problem with the latest version, it might be a good idea to upload the gcode from both so can compare one vs the other.
Also if you upload your project file from the latest version of Cura, people will be able to view all the settings, that way if the gcode shows different lines of code at the start people could see if it’s a setting or a bug.
