The OctoPrint Connection plugin detects if the CuraThumbnails plugin is installed, and sends files to OctoPrint as .ufp without having to configure anything in Cura, regardless of the printer brand.
2 hours ago, sekisback said:I found under PrinterSettings that i can change the G-Code-Var. In my case by default "Marlin", I changed this to Ultimaker2 without effect.
Don't do that, that will not work with your printer and it will not in any way affect the use of .ufp files.
Smithy 1,145
It works with an UM printer and the Octoprint plugin, so there should be also an easy way to get it with an Ender too.
Let's ask the expert @ahoeben
