When it does an auto home it sends the nozzle to the back-right corner and activates the end stops. Isn't the home position on an Ender 5 supposed to be at the front left? I'm using the Unified Firmware version 1 from TH3D in the printer.
Thanks for the help!
Steve Hurd
GregValiant 1,330
It's a printer setting - you need to alter your Home Offsets. Your X and Y are going to end up near zero (Z will be zero).
After sending the print head Home, jog the X until the nozzle is just inside the left edge of the build surface. Then jog the Y until the nozzle is just inside the front edge of the build surface. On the LCD hit Set Home Offsets (or whatever it's called).
The center of the build plate will end up real close to X117.5 and Y117.5
Is that a skirt? If it is then change the "Skirt Distance" to 1 and you will pick up a little room.
Edited by GregValiantLink to post
