It could be and this is just guessing, that the filament was retracted too much from a previous print and now needs some layers to get back to the nozzle. This happens often when you change to Marlin with the code flavour and then you have to edit the start code to prime a little bit more filament, that the material is in the nozzle when the print starts.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Smithy 1,141
