I've followed all those steps a number of times, the problem comes with step 4 when loading the PVA.
Only a very, very small amount comes out of the nozzle if any at all, cerainly not a consistent flow.
After waiting a while for a consistent flow to appear the confirmation message times out & the printer appears to assume that the material has loaded when in fact it hasn't. This becomes aparent when I try to use the material & nothing gets extruded from its nozzle.
Smithy 1,146
Just to be sure you do the load procedure correctly:
Are these the steps you did? I have the feeling you missed the confirmation after putting the filament into the feeder.
