Help on site needed to check Ultimaker 3
LDM
Posted · Help on site needed to check Ultimaker 3
Hello, this is about the Ultimaker 3 from the British Senior school in Leidschenveen, The Netherlands.
Where could I find somebody with knowledge of this 3D printer to come and check it? the first prints worked very well but after those we can't make it work.
Thank you.
Laura.
    46 minutes ago, SandervG said:
    I don't know where you bought it, but have you tried contacting your reseller? Otherwise I think Lay3rs might be able to help.
    thanks. I will try both.
