Where did my Profiles go?
LePaul
Posted · Where did my Profiles go?
Hi
This one has me stumped.
My peers send me the Cura Projects so I can open them and see the print settings, model and how everything is set for their print request.
One thing I notice, even if I close out and start new, is the various Profiles are missing.  Such as the 0.1 , etc etc...   How do I get these back?
    Posted (edited) · Where did my Profiles go?
    Due to the nature of my work I can't.
    I just tried adding an Ultimaker S5 again and now I have them back (didn't work previously but closed and restarted Cura)
    We're trying to use a workflow where they send me their project so I can see the model and Cura settings (similar to what we do with S3D).  This way if their settings are incorrect, I can either make changes...or if it is quicker to use one of Cura's built in profiles, I can use that.
    Is that a good process or do you advise another method?
    Thanks
    Edited by LePaul
    Yeah that is a good workflow, which is also why I'm asking for the project file.
    Anyhow. Could you just send a project file without the model in it? I'm just interested in what profiles are active (since that is where the problem is).
    My guess is that somewhere you have a BB nozzle selected for a material that doesn't need it. That's usually why and when this happens.
    That's an interesting point.
    The user didn't match what the S5 had loaded for Cores and Materials.
    I changed them over via the Settings menu but then lost the profiles in doing so.
