Here's another way to do multi color prints with a single extruder:
22 hours ago, gr5 said:Well the way you seem to be attempting to do it...
Go to menu item "preferences" "configure cura..."
Uncheck the box by "automatically drop models to the build plate".
Now load your second STL that you want at 1mm. click on that part and on the left side use the tool that allows you to move your part around. In the Z box type in "1mm". Make sure support is disabled.
Now you have a second gcode file - one for the base part and one for the second color part.
When I try this, than this happens
I'm not sure what I'm seeing. You have to also disable brim and support so it doesn't print the bottom few layers and you have to position the height. In the photo above you are on the scale tool. You don't want to scale. You want to set the Z position.
The scale tool just was a coincidence, support was disabled, and the brim/skirt was disabled. However I don't know how to set the z position.
You click on the part. Click on the move tool on the left side. Now there are 3 arrows for moving in XYZ. On the left is a box. Just type in the number of mm to raise the part in the Z box.
20 hours ago, gr5 said:You click on the part. Click on the move tool on the left side. Now there are 3 arrows for moving in XYZ. On the left is a box. Just type in the number of mm to raise the part in the Z box.
the problem is that the print in the preview drops down as you can see in this video
So there are two models, right? You merged them. I think you only want to merge them if you have a dual nozzle printer. You said you only had one extruder, right?
So don't merge the models.
Not only should you not merge the models - you should only load one at a time as you are creating two separate prints, right? You want to print one in one color and then print the other in the other color. Two separate prints. That happen to print one on top of the other.
With "Generate Support" disabled, untick "Remove Empty First Layers" under "Mesh Fixes".
Alternatively: 1) Adjust the high. 2) Click "Support blocker" (sixth icon on the left) click anywhere to place it. 3) Select the cube, click "Per model settings" (fifth icon on the left) and click "Normal model". 4) Click "Select settings", select "Wall line count", "Top Layers", "Bottom layers" and "Infill density", set all of them to 0 and slice you model.
gr5 2,330
