I appreciate your idea. We have multiple S5 printers in some locations. Assuming that workaround would work, we could then only print on the one printer with that name per location. Hope there is a better way. Thank you.
Yeah, we recently added that feature. I'm not quite sure if it's in 4.7, but i'm sure it will be in 4.8.
Previously you would only get a "update" or "create new" when you loaded a 3mf file. In the new worlkflow you will get "Update machine A", "Update machine B" and "create new". When selecting "Update machine ...." it will take the settings from the project file and apply them to that machine.
- 1
Thanks @nallath, good to hear. We are looking forward to 4.8.
Mari 37
Maybe stupid idea: you all use the same printername?
