Spiralize will do the outer wall of the model and vary the Z in increments until it comes around to the "Layer Start". At that point it will be one layer height above the previous Layer Start and it just keeps moving.
EXCEPT it does print the bottom of the model in a conventional way using the Bottom Layers setting and doesn't start to spiralize until it gets above that. I would expect to see typical gcode (like what you have) up till Bottom Layers +1 where the speed will drop and the number of gcode lines with a Z move goes way up and is incremental as the head moves around the periphery.
So if you want to spiralize right from the get-go then set Bottom Layers to zero.
GregValiant 1,112
