I rarely print temperature towers, because I never got a clear result which temp I should use. It also depends on your model.
I print a lot with the 0.8 core and normally use the default temp settings and don't touch it. I only adjust it +5°C or 10°C if I print with 0.4 layer height and faster.
You should also keep in mind that you get not the details you know from the 0.4 core and that the whole print is not so nice and smooth. Also bridges are not very beautiful as you can see.
donogh 2
Tried a 20mm test cube with the same settings @ 190C and it came out reasonably well:
Going to try a more complex print and see how it turns out...
