Posted · material not detected
Hi All
was wondering if someone can help all of the sudden my S5 cannot detect materials being loaded. i get a massage that reads multiple materials detected load one material at a time.
I then select a material from the list below and every time i start a job i get a message showing conflicts.
How do i repair this problem
    That you get the conflict warning is normal when you select the material manually, because it that case the printer expects a generic material.
    have you checked if the NFC cable is well connected? Maybe disconnect and connectivity again.
