Posted · Bad quality in inner wall surface
I have the issue where I'm printing a coffee mug. Outer wall seems to have a reasonably good surface and is respecting the Z seams position. But inner wall surface has bad quality and shows some small gaps. I have set up the same slower speed for outer and inner walls in Cura. I'm printing in PETG with the suggested temperature, speeds, retraction settings, etc. How can I make Cura print the inner wall in the same quality of outer wall.
    • 4 months later...
    Posted (edited) · Bad quality in inner wall surface
    Hello,
    did you get a solution for this issue ? I have the same, the outer Wall is almost perfect in good quality and the inner Wall ist like yours very poor quality.
    Edited by Piccanto
