nalath, yes. I have network drives connected. But they areN#t related to any search pathes for Cura.
I just disabled my WIFI and cura was fast again... Hm, don't want to disconnect all my drives, though...
It's a known issue that Cura is super slow to start if the X drive is used (if i recall correctly). Since that doesn't happen often it never got priority to get fixed.
I am not sure if this is related. this sounds like how my Cura 4.7 ran yesterday after the Microsoft update. Then I downloaded 4.8 and installed and I still had the same problem. I had a similar problem this summer with Autodesk Fusion 360 hanging and was able to fix by starting task manager and killing any process related to Nahimic. Then I ran Cura and it popped right up. I am using 3 monitors on a system that used to have a video card that used nahimic services and they are harder to get rid of than any addiction. I can't find anything that I need Nahimic services for.
Exactly 10 minutes ago I wrote a similar impression:
"I have Ender 3 Pro for 2 months, I tried several popular slicer programs, but I most liked Cura.. I think I learned to use it well and made 4-5 profiles very suitable for me and I had fun with almost always successful 3D prints for 2 months (about 3 kg printed)
Suddenly, however, the program stopped working and I have no solution of the problem. For 3 days I tried everything I saw and nothing worked.
At startup, the program stays with the taskbar as working, but absolutely nothing else happens. After dozens of attempts to fix the problem, the best I managed to achieve is that sometimes the startup screen is displayed and remains in the position of loading plugins...and again noting more happend..
I tried all the popular solutions but nothing worked.
Complete uninstallation and reinstalled on new and old versions .. does not work
remove Visial C ++ libraries as described .. reinstall..any combination..does not work
Clearing registers, uninstalling the program ... everything possible does not work.
Video driver update (Nvidia GTX 1080) .. does not work
A problem I think (but I'm not sure) appeared after the latest updates of Windows 10 (20H2).
I think a few days before it stopped working, the startup process had become too long.
The situation for me is completely unreliable at the moment and I will have to switch to using another program ... or another computer. unfortunately quite inconvenient for me solutions, but I can not afford a complete reinstallation of the computer in question ..
I do not know why such a popular and successful program behaves in such a strange way, I saw that other reports of such behavior have been published .."
and I just see the comments here..
For me, the problem was solved when I stopped the LAN network ... everything works fine without a LAN network. It seems amazing the decision that in order to use Cura, you have to disconnect the Lan.. Unbelievable 🙂
Yes, having network drives mapped, or more specifically drive letter X:, made Cura really slow on everything (slow start, slow in menu, slow to slice, unbearably slow, and 0% load). Uninstall and reinstall didn't help, but unmapping the drive letter X: did! Back to fast and good Cura again! :-)
QuoteYes, having network drives mapped, or more specifically drive letter X:, made Cura really slow on everything (slow start, slow in menu, slow to slice, unbearably slow, and 0% load). Uninstall and reinstall didn't help, but unmapping the drive letter X: did! Back to fast and good Cura again! 🙂
It really works (for now)! 🙂
Thank you Erik 🙂
nallath 1,124
Do you have a network drive enabled?
Mightycoco 0
The initialization alone took 20 Minutes. Then look at the timings of the MainThread. It took 45 more Minutes until the UI was available. So overall it was more than one hour to start the application.
C:\Program Files\Ultimaker Cura 4.7>CuraCLI.exe --debug
[MainThread] UM.Qt.QtApplication.__init__ [81]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.7\PyQt5\plugins
[MainThread] UM.Qt.QtApplication.__init__ [91]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.7\PyQt5\plugins
[MainThread] UM.Application.initialize [144]: Initializing Ultimaker Cura
[MainThread] UM.Application.initialize [145]: App Version 4.7.1
[MainThread] UM.Application.initialize [146]: Api Version 7.3.0
[MainThread] UM.Application.initialize [147]: Build type None
[MainThread] UM.Resources.__initializeStoragePaths [446]: Initializing storage paths
[MainThread] UM.Resources.__initializeStoragePaths [456]: Config storage path is C:\Users\mcu\AppData\Roaming\cura\4.7
[MainThread] UM.Resources.__initializeStoragePaths [464]: Data storage path is C:\Users\mcu\AppData\Roaming\cura\4.7
[MainThread] UM.Resources.__initializeStoragePaths [476]: Cache storage path is C:\Users\mcu\AppData\Local\cura\4.7\cache
[MainThread] UM.Qt.QtApplication.initialize [144]: Preferences file not found, ignore and use default language 'en_US'
[MainThread] UM.PackageManager.__init__ [54]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.7\resources\bundled_packages\cura.json
[MainThread] UM.PackageManager.__init__ [54]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.7\resources\bundled_packages\uranium.json
[MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [118]: Trying OpenGL context 4.1...
[MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [128]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
[MainThread] UM.Qt.QtApplication.initialize [173]: Detected most suitable OpenGL context version: 4.1 Core profile
[MainThread] UM.Qt.QtApplication.initialize [180]: Initializing job queue ...
[MainThread] UM.Qt.QtApplication.initialize [184]: Initializing version upgrade manager ...
[MainThread] UM.PackageManager._loadManagementData [165]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.7\resources\bundled_packages\cura.json
[MainThread] UM.PackageManager._loadManagementData [165]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.7\resources\bundled_packages\uranium.json
[MainThread] UM.PackageManager._loadManagementData [186]: Loaded user packages management file from C:\Users\mcu\AppData\Roaming\cura\4.7\packages.json
[MainThread] UM.PackageManager._saveManagementData [256]: Package management file C:\Users\mcu\AppData\Roaming\cura\4.7\packages.json was saved
[MainThread] UM.PluginRegistry.initializeBeforePluginsAreLoaded [110]: Loading plugin configuration file 'C:\Users\mcu\AppData\Roaming\cura\4.7\plugins.json'
[MainThread] UM.Logger.info [122]: Loaded plugin 3MFReader
[MainThread] UM.Logger.info [122]: Loaded plugin 3MFWriter
[MainThread] UM.Logger.info [122]: Loaded plugin AMFReader
2020-11-04 12:15:08,632 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ConsoleLogger
2020-11-04 12:15:22,806 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CuraDrive
2020-11-04 12:15:22,902 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.__init__ [92]: Found CuraEngine at: C:\Program Files\Ultimaker Cura 4.7\CuraEngine.exe
2020-11-04 12:15:37,024 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CuraEngineBackend
2020-11-04 12:15:51,284 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CuraProfileReader
2020-11-04 12:16:05,530 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
2020-11-04 12:16:19,768 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.7\CuraEngine.exe
2020-11-04 12:16:33,986 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.7\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '', '-vvv']
2020-11-04 12:16:55,293 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2020-11-04 12:17:02,397 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
2020-11-04 12:17:16,652 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.7.1
2020-11-04 12:17:23,756 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
2020-11-04 12:17:37,948 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CuraProfileWriter
2020-11-04 12:17:37,948 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2020 Ultimaker
2020-11-04 12:17:52,178 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2020-11-04 12:18:06,402 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
2020-11-04 12:18:20,614 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
2020-11-04 12:18:34,860 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
2020-11-04 12:18:49,070 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
2020-11-04 12:18:49,078 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin OBJReader
2020-11-04 12:19:03,270 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2020-11-04 12:19:17,489 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin OBJWriter
2020-11-04 12:19:17,496 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
2020-11-04 12:19:31,679 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
2020-11-04 12:19:45,887 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
2020-11-04 12:19:45,887 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin STLReader
2020-11-04 12:20:00,095 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
2020-11-04 12:20:14,287 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin STLWriter
2020-11-04 12:20:14,295 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2020-11-04 12:20:28,502 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
2020-11-04 12:20:42,685 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FileLogger
2020-11-04 12:20:42,693 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>.
2020-11-04 12:20:56,949 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Connecting to 127.0.0.1:49674
2020-11-04 12:21:11,150 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdateChecker
2020-11-04 12:21:11,158 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Connected to 127.0.0.1:49674
2020-11-04 12:21:39,580 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdater
2020-11-04 12:21:53,838 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzReader
2020-11-04 12:22:08,026 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzWriter
2020-11-04 12:22:22,260 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeProfileReader
2020-11-04 12:22:50,650 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeReader
2020-11-04 12:23:04,852 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeWriter
2020-11-04 12:23:19,110 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ImageReader
2020-11-04 12:23:33,340 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LegacyProfileReader
2020-11-04 12:23:47,561 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalContainerProvider
2020-11-04 12:24:01,749 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalFileOutputDevice
2020-11-04 12:24:15,963 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MachineSettingsAction
2020-11-04 12:24:30,194 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ModelChecker
2020-11-04 12:24:58,649 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MonitorStage
2020-11-04 12:25:27,203 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PerObjectSettingsTool
2020-11-04 12:25:55,652 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PostProcessingPlugin
2020-11-04 12:26:24,178 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PrepareStage
2020-11-04 12:26:52,608 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PreviewStage
2020-11-04 12:27:21,072 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RemovableDriveOutputDevice
2020-11-04 12:27:49,544 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SentryLogger
2020-11-04 12:28:17,984 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimulationView
2020-11-04 12:28:46,449 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SliceInfoPlugin
2020-11-04 12:29:14,877 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SolidView
2020-11-04 12:29:43,294 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SupportEraser
2020-11-04 12:30:11,694 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-04 12:30:40,196 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-04 12:31:08,592 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-04 12:31:37,063 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-04 12:32:05,454 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-04 12:32:33,855 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-04 12:33:02,298 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-11-04 12:33:30,816 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-11-04 12:33:59,330 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin Toolbox
2020-11-04 12:34:27,825 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CameraTool
2020-11-04 12:34:56,314 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MirrorTool
2020-11-04 12:35:24,767 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RotateTool
2020-11-04 12:35:53,184 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ScaleTool
2020-11-04 12:36:21,535 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SelectionTool
2020-11-04 12:36:49,916 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TranslateTool
2020-11-04 12:37:18,492 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TrimeshReader
2020-11-04 12:37:46,923 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPReader
2020-11-04 12:38:15,398 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPWriter
2020-11-04 12:38:43,854 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UltimakerMachineActions
2020-11-04 12:39:12,326 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UM3NetworkPrinting
2020-11-04 12:39:12,422 - INFO - [Thread-1] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
2020-11-04 12:39:40,770 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UpdateChecker
2020-11-04 12:40:09,214 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin USBPrinting
2020-11-04 12:40:37,690 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade21to22
2020-11-04 12:41:06,174 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade22to24
2020-11-04 12:41:34,612 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade25to26
2020-11-04 12:42:03,056 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade26to27
2020-11-04 12:42:31,517 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade27to30
2020-11-04 12:42:59,897 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade30to31
2020-11-04 12:43:28,372 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade32to33
2020-11-04 12:43:56,810 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade33to34
2020-11-04 12:44:25,278 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade34to35
2020-11-04 12:44:53,748 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade35to40
2020-11-04 12:45:22,183 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade40to41
2020-11-04 12:45:50,610 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade41to42
2020-11-04 12:46:19,026 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade42to43
2020-11-04 12:46:47,452 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade43to44
2020-11-04 12:47:09,065 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade44to45
2020-11-04 12:47:37,957 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade45to46
2020-11-04 12:48:06,411 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade460to462
2020-11-04 12:48:34,832 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade462to47
2020-11-04 12:49:03,277 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimpleView
2020-11-04 12:49:31,719 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin X3DReader
2020-11-04 12:50:00,121 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XmlMaterialProfile
2020-11-04 12:50:28,591 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XRayView
2020-11-04 12:50:42,810 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [373]: Loading all plugins took 2176.8762590885162 seconds
2020-11-04 12:50:57,069 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
2020-11-04 12:51:11,309 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [175]: Checking and performing updates took 14.259205102920532
2020-11-04 12:51:25,532 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [226]: The preferences file cannot be found or it is corrupted, so we will use default values
2020-11-04 12:51:39,769 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [235]: The preferences file 'None' cannot be found, will use default values
2020-11-04 12:52:12,725 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [361]: Loading metadata into container registry took 18.530343294143677 seconds
2020-11-04 12:52:26,948 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
2020-11-04 12:52:41,178 - INFO - [MainThread] cura.CuraApplication.run [781]: Initializing machine error checker
2020-11-04 12:52:55,431 - INFO - [MainThread] cura.CuraApplication.run [786]: Initializing machine manager
2020-11-04 12:53:09,677 - INFO - [MainThread] cura.CuraApplication.run [791]: Initializing container manager
2020-11-04 12:53:09,976 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [295]: The definition cache for definition fdmprinter failed to pickle.
2020-11-04 12:53:23,971 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
2020-11-04 12:53:38,235 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.7\resources\themes\cura-light\theme.json
2020-11-04 12:53:52,511 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [246]: Loaded theme C:\Program Files\Ultimaker Cura 4.7\resources\themes\cura-light
2020-11-04 12:53:57,138 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [336]: Creating post processing plugin view.
2020-11-04 12:53:57,186 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: ChangeAtZ
2020-11-04 12:53:57,218 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: ColorMix
2020-11-04 12:53:57,234 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: DisplayFilenameAndLayerOnLCD
2020-11-04 12:53:57,258 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: DisplayProgressOnLCD
2020-11-04 12:53:57,274 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: FilamentChange
2020-11-04 12:53:57,298 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: InsertAtLayerChange
2020-11-04 12:53:57,322 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: PauseAtHeight
2020-11-04 12:53:57,354 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: RetractContinue
2020-11-04 12:53:57,386 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: SearchAndReplace
2020-11-04 12:53:57,410 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: Stretch
2020-11-04 12:53:57,434 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: TimeLapse
2020-11-04 12:53:57,458 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: UsePreviousProbeMeasurements
2020-11-04 12:53:58,162 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [346]: Post processing view created.
2020-11-04 12:54:06,814 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-11-04 12:54:21,075 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-11-04 12:54:35,294 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
qml: TableViewSelection: index out of range
2020-11-04 12:54:49,526 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
2020-11-04 12:55:03,773 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
2020-11-04 12:55:18,014 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.7/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:143: TypeError: Cannot read property 'hasRemoteConnection' of null
2020-11-04 12:55:32,283 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
2020-11-04 12:55:32,340 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [117]: Creating model checker view.
2020-11-04 12:55:32,388 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [126]: Model checker view created.
2020-11-04 12:55:32,388 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
2020-11-04 12:55:32,636 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [544]: Requesting [updates] metadata from server.
2020-11-04 12:55:46,532 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [124]: No auth data to retrieve the access_token from
2020-11-04 12:56:00,786 - WARNING - [MainThread] UM.Logger.warning [128]: Cannot add authorization to Cloud Api request
2020-11-04 12:56:14,988 - DEBUG - [MainThread] cura.CuraApplication.run [830]: Booting Cura took 2821.9168968200684 seconds
2020-11-04 12:56:14,996 - DEBUG - [Thread-2] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
Proxy query URL too long for windows API, try with truncated URL
2020-11-04 12:56:29,336 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [62]: Updating QualityProfilesDropDownMenuModel.
2020-11-04 12:56:29,344 - DEBUG - [Thread-2] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
2020-11-04 12:56:43,607 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [74]: No active GlobalStack, set quality profile model as empty.
2020-11-04 12:56:57,797 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
2020-11-04 12:57:11,993 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [38]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty.
2020-11-04 12:57:26,178 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
2020-11-04 12:57:40,412 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
2020-11-04 12:57:54,627 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version: 4.1.0 - Build 24.20.100.6293
2020-11-04 12:58:08,989 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor: Intel
2020-11-04 12:58:16,121 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics 520
2020-11-04 12:58:30,430 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version: 4.10.0
2020-11-04 12:59:05,984 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\default.shader]...
2020-11-04 12:59:27,276 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\selection.shader]...
2020-11-04 12:59:41,488 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\select_face.shader]...
2020-11-04 12:59:55,670 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\default.shader]...
2020-11-04 13:00:09,869 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\composite.shader]...
2020-11-04 13:00:24,070 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\overhang.shader]...
2020-11-04 13:00:38,279 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\striped.shader]...
2020-11-04 13:00:52,496 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\transparent_object.shader]...
2020-11-04 13:01:06,671 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\striped.shader]...
2020-11-04 13:01:20,871 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\xray.shader]...
2020-11-04 13:01:28,265 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\xray_composite.shader]...
2020-11-04 13:01:42,487 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\platform.shader]...
2020-11-04 13:01:56,683 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.7\resources\shaders\xray.shader]...
2020-11-04 13:02:18,007 - DEBUG - [MainThread] cura.AutoSave._onTimeout [59]: Autosaving preferences, instances and profiles
