Posted (edited) · No height alignment with CURA 4.8?
I used the automatic alignment (CTRL + R) in Cura to automatically align objects to the build plate.
Till Cura 4.7 the alignment worked also for the height, this means if I imported a object and it flew over the build plate I hit CTRL + R and its on the build plate aligned and ready to print.
Since 4.8 this is no longer working.
Does anyone have the same issue and is this a bug in Cura 4.8?
Edited by Mad
    Posted · No height alignment with CURA 4.8?
    There is a setting in the preferences called "Automatically drop models to the build plate" which should be checked. Then the model will be always dropped to the build plate during loading.
    • 3 weeks later...
