slicing my design, not for the print etc, but to tile a larger design?
Posted
(edited)
· slicing my design, not for the print etc, but to tile a larger design?
"...like you would if in 2D print you printed on 4 sheets of paper for a larger print".
You pose an interesting question. The short answer is "yes you can". My question is "do you really want to?".
It really takes a lot of thought to move those separate pieces of paper around on your kitchen table, align them to each other, and then tape them together so they don't move when you cut out the full shape with scissors. Part of that "process" is to make sure that each piece of paper has witness lines that will line up with the next piece of paper. That gets done ahead of time, not when you have them on the kitchen table.
By fudging the build plate size in Machine Settings, changing the Home Offset in your printer, and using support blockers you can get Cura to slice the model within your "real" build plate area. With the support blockers configured as "Cutting Mesh" you could print it in sections and then screw or glue the sections together.
How are you going to locate the finished sections in space relative to each other? Each section will have a flat face that mates to the flat face on the next section. Each face is a featureless slip plane. If the bottom of each piece is flat, you could apply glue and slide them together while guessing that the last plane (X or Y) is aligned by eyeballing it. I'm not a fan of simply "eyeballing" things into position.
When I print large models I make them into sections in CAD. Each section of my model mates to the next via features that are common to both pieces. If the piece is large enough for it, there will be locating pins in one piece and mating holes in the next. All of that needs to be in the design rather than in the slicer. One way to locate things is to put 2mm mating holes in each part, cut pieces of filament as locating pins, and glue them into one part, and drop the other part onto the pins. The parts are "absolutely" located relative to each other.
This is the Cafe Racer tail section for my motorized bicycle. It required two large prints because it was too big for the Ender to take the whole thing at once. (GET YOUR MINDS OUT OF THE GUTTER PEOPLE!!!)
This shows the interface between the two sections. Since this is a functional part, it needed to be screwed together. The 3 screw holes on the front part have collars, and the mating holes on the rear part have counterbores to accept them. The hex nuts are trapped because I couldn't get both hands into it to hold the wrench while screwing. (Damn, I did it again!).
My "Hardley Davison". The nitrous tank is opposite the fishing rod holder. Yes, I'm a Detroit boy.
Edited by GregValiant
Are you a startup using 3D printing? Perhaps you should continue reading...
Together with BASF we are launching the Forward AM Innovation Award - the very first global contest for startups developing new applications with 3D printing!
Why apply?
The winning startup will receive €100,000 in goods and services*, along with coaching and marketing exposure from top-notch leaders in the industry.
Who can apply?
Your startup creates products using Additive Manufacturing, is less than 5 years old, and has less than 50 employees. We are looking for 3D printing applications with a strong focus on innovation, sustainability and scalability.
Dental aligners, shoes, tools, automotive parts, music instruments, industrial tooling and molding, medical implants, sports equipment, toys, architecture, fashion, construction... all are welcome to join!
Do you have an innovative, sustainable and scalable idea that leverages the unique possibilities of 3D printing? Then it is time to apply!
More information can be found here.
Applications close on March 28th, 2021
* What does "in goods and services" mean?
The winner will be able to pick any item from the overall product and service portfolio of the sponsors, e.g. printers, materials, consulting, software... Choose whatever you need to accelerate your startup.
GregValiant 193
