No temperature selection is in the material section possible
mslunsky
Posted · No temperature selection is in the material section possible
When UM 2+ext ist selected i cannot chage the temperature as the menue doesn't show any values. When I select instead an UM (1) or UM 3 Ican change all temperature settings. Is this a Bug?
    It's a feature of the UM2 series.
    Short answer:
    (very) long answer: 🙂
