Bug: Bridge settings prevent changing direction of lines.
Gerrardh
Posted · Bug: Bridge settings prevent changing direction of lines.
I've seen others complain about this (in 2019), but I haven't seen bug raised yet - hence the post.
Enabling "Bridge settings" defaults to the bridge taking the longest path from point to point, and this is not configurable.
I've attached a series of images - I've changed the values for the top and bottom line directions (0 and 90°), I've tried changing the top/bottom line pattern, and changing the orientation of the part - none of these work - as you can see in the images the lines run the full length of the part in each case. When I disable bridge settings the lines run across the part as they should.
Please change the default behaviour and/or expose the bridge direction variable for the user to set as desired.
Thanks
So I decided I would use Change at Z post process to add a lower speed for this particular layer as a work around, after checking the gcode in Cura, I needed to restart. After re-starting, the problem doesn't exist. I now have bridge settings enabled, and the line direction is across the part - not along it.
I guess the bug should be updated to "sometimes"? I definitely wasn't working earlier, but now it is.
So weird!
    • 7 months later...
