Yes, but that didn’t change anything 😞
I’m guessing it may have to do with the fact I am using 3dprinteros, which allows me to use my UM3 from an iPad. Is there a way to go back to the previous firmware version (where everything was still working perfectly)?
I think reverting to the previous version should work. Just download the firmware from the UM website, copy it to a USB stick and do the downgrade from the stick. Not 100% if it really works or if there is a check which prevents you from downgrading, but I think it should work.
Unfortunately it seems that the only downloadable versions are the latest and a really old version 4.3.97, or am I missing something?
In the end I found that by replacing the link to the latest release with the numbers of the previous (which I found in an email on this forum) I could download the previous version from:
The downgrade worked perfectly, and now I have ssh access again in the developer mode, and I can use 3dprinteros again to print from my iPad! 😀
Great and I am glad that you were able to fix it.
Smithy 1,145
Have you already tried to disable the developer mode and enabled it again?
