Cura is not tested on Windows 7 anymore. Microsoft has stopped supporting that version, and so has Ultimaker. I don't think the amount of memory is the problem, but compatibility between Windows 7 and the Qt (the UI framework used in Cura) is a more likely culprit.
It works like a charm on Windows 10. So now I'll always have to get out my laptop to get something sliced.
Anyway, problem solved!
Thank you for your assistance ahoeben!
ahoeben 1,763
Cura only shows those buttons for the "active" printer. You have multiple printers added to Cura, and only one of them is active. Use the "Activate" button in that dialog.
By the way, there seems to be something fishy going on with your UI. The topbar has gone transparent. Did you create a theme for that, or should we try to diagnose that issue too?
Evelien 0
Thank you for your reply ahoeben.
I see what you mean, the top bar is transparent indeed. I never knew it should not look like that. I have not created a theme or anything like that, Cura is purely as it "came out of the box", with only the scaling addon from the Marketplace installed as an extra.
Pressing the Activate button does not make the control buttons for any printer appear.
My suspicion is that my machine does not have enough memory to make Cura work correctly (even though I do have 8GB of RAM in my 64-bit Windows 7 machine). Could a lack of available memory lead to symptoms like we see here?
Best regards,
Evelien
