TPU 95A has a shore hardness of 95, I think. So that is quite stiff, much like hot glue after cooling down. If you print it in a thin layer of 0.1-0.2mm it will be flexible, but not in thick parts.
You could try playing with less infill, but I have no experience with this, so no recommendations.
If you need really soft materials, you could consider printing a mould, and then casting silicone in it. This exists in various hardnesses. There have been several posts about casting silicones, maybe you can search them?
I see! I will look up on the casting and continue experimenting with the thickness. Thank you so much for the advice! 🙂
geert_2 558
CliffeRain 0
