so i should change the standard settings for the ultimaker pla ? and it is accurate but not the same as the file. if iprint the part multiple times it is always the same in dimensions it is just not the correct dimension
Yes, try these settings:
Line Width: 0.4 (all line widths 0.4)
Wall Thickness: 1.2
Wall Line Count: 3
Top/Bottom Thickness: 1.2
Print Speed: 30
Infill Speed: 30
Wall Speed: 30
Outer Wall Speed: 30
Inner Wall Speed: 30
Top/Bottom Speed: 30
Print Jerk: 30
Infill Jerk: 30
Wall Jerk: 30
Outer Wall Jerk: 30
Inner Wall Jerk: 30
Top/Bottom Jerk: 30
Horizontal Expansion: -0.03
These settings can also help:
Outer Before Inner Walls = checked
Combing Mode = off
Slicing Tolerance = Exclude
Smithy 1,141
It mostly depends on the material, speed, print temperature and so on....
So print as cool as possible and not faster than 35mm/sec. It also helps to equalize all the speeds to the same value. Search the forum here for dimensional accuracy and you will find some posts with the relevant settings.
