GregValiant 1,321
When you have small parts, these "Travel" settings come into play. They are described in their ToolTips.
Minimum Extrusion Distance
Retraction Minimum Travel
Max Comb Distance with No Retract
If your Max Comb Distance with No Retract is set higher than the width of that part, then there will be no retraction for the combing moves you have highlighted.
ViperZ 0
I think it's a bug because there is no retraction
