Hi StudioKubuz,
Thanks for your response.
I will check the retraction setting, can't do it right now.
But it is strange that one setting (doesn't matter which one) can change the direction of the feeder.
I thought that the feeder has nothing to do with a print but is allways going one direction and one direction only.
I also thought that with the firmware set by Cura, is setting the original settings.
StudioKubuz 4
I had the same problem with my Ultimaker 2, after upgrading last week.
Revert it back to the original settings. and all was fine.
Its very strange its changes direction in mid-print.
Could it be that your retraction settings are at 10 x of the default.
Absolutely not sure. But it may be worth it to check.
