Cura uninstall and reinstall every open
Frustration
Posted · Cura uninstall and reinstall every open
I have had this problem every time I open cura. When I run the program a prompt comes up asking me if I want to uninstall the old version before installing the new one. but I have the new one. So in order to open the program once, I need to uninstall the up to date functioning software and redownload it every time.  This also means i cannot install plug-ins as they require a re-start to be installed.
    You seem to be starting the installer instead of the application that gets installed by the installer. After installing, do not run "Ultimaker_Cura-4.8.0-amd64.exe" again, but instead run "Ultimaker Cura 4.8.0".
    Note that you can also answer "no" to that question, which would leave "the new one" in place before installing it again.
        • 4 replies
