Posted (edited) · filament wraps the product like a spider web.
filament wraps the product like a spider web. why this happening ?
0.4mm nozzle
ESUN PLA+ Filament 215 C Printing Temperature
Edited by tarikkah
    Posted · filament wraps the product like a spider web.
    I think you have multiple problems there.
    The support appears to be extremely under-extruded.
    There is a lot of stringing and oozing (usual a problem with the temperature and retract settings.)
    What printer is that?  If you could do a "File | Save Project" and post the .3mf file here it would really help.  The gcode file would be less helpful but maybe put that up here too.
    • 2 weeks later...
    Here is the stl file . Thanks for helping.
    Mudhorn_Clan_v3.stl
    The STL file doesn't help because it doesn't have any settings in it.  Please provide a "Project File" so people can tell how you set up Cura to slice the model.
    As with many "character" models, this model has problems.  It is not "watertight" and that model file is HUGE.  Try printing something simpler, but that needs some support.
    You still haven't mentioned what printer it is.
    You might need to calibrate your E-steps.
    There are numerous "Flow" settings in Cura.  Search the settings for "Flow" and make sure they are at 100%.  Make sure you have "Retraction" set.  Start at 5mm.
    No clogs in the nozzle?  No blockage in the hot end?
