Preview issues viewing layers
Husar
Posted · Preview issues viewing layers
Just today viewing layers after slicing stopped displaying.   After I slice any model then go to Preview the layer display doesn't show me anything.  See the screen shot I attached.   Running Catalia 10.15.7.  Any idea what is happening or cause this?
.1623540871_ScreenShot2021-01-01at3_05_31PM.thumb.png.287dd46c3e8cf6e2487528ff147bc336.png
    Posted (edited) · Preview issues viewing layers
    Does moving the layer slider on the right hand side of the screen cause the preview to look normal again?
    If the issue happened because you no longer have the option to slice the file, then try going to the general preferences menu and enabling then disabling the autoslice option. That usually helps force it to let you slice manually again.
    Edited by Priddy
    Added info
