...nozzle widths of .4-.7 ... speeds I set to 20-300 which might be a bit high...
I'd definitely start with less agressive settings until you get something working then move up. Maybe try 0.4mm-0.6mm thread widths and 50-100mm/s speeds.. Even that may be too fast for a 0.02mm layer - maybe try 20-50mm/s first.
I suspect it's not really any individual setting combination that can cause problems - it's more like about the rate of change from one setting to another, within a print. A 0.4mm thread at 20mm/s is about 1/25th the extruder speed of 0.7mm at 300mm/s. These are VERY different settings that you're allowing in the same print...
Eventually, I think slicers will get smart enough to compensate for this and do sortofa more-gradual ramp from one setting to the next. We're not there yet, though.
Thanks for the tips ddurant, I changed my profile and i've started another print. Here's a pic for posterity. Still working on how to post .reprapcalibration files. Maybe we can get those white listed?
ddurant 0
