PP print thin UM3
ricciojm
Posted · PP print thin UM3
Hello Ricciojm,
I've printed PP on a UMS5 with succes. The challenge is to make the PP stick to the glass. I usually spray a thin coat of 3DLac an use a brim. Also PP has a high shrink factor. Usually I have to scale the part 1% larger in X and Y.
