No, I dont use RDP. I use Cura locally. One more thing: everething worked before I reinstalled my system
15 hours ago, malderli said:everething worked before I reinstalled my system
This is indicative - to me - that your gpu driver is the problem. Either you don't have a properly installed driver for your gpu, or the driver specifically excludes support for OpenGL. I would not think the latter is likely.
ahoeben 1,160
The problem is that when Cura asks your system if it supports at least OpenGL 2.0 (after first asking if OpenGL 4.1 is supported), your system says "no".
Are you perhaps trying to start Cura over an RDP ("Remote Desktop") connection? If so, that is known to interfere with your system reporting about its OpenGL capabilities.
