Import profiles from Cura 3.6 to 4.8
ZSR2010
Posted · Import profiles from Cura 3.6 to 4.8
Hello!
I recently added a new printer to personal print farm. I already had a LulzBot Mini using Cura LulzBot Edition. I want to import all the great profiles to 4.8 with out having to manually input tons of different printer settings and material profiles. Is there away to bring them all in even if it's a little bit of a round about way?
