Posted · Camera settings in Cura?
I'm ordering an Ultimaker 2 on Monday, so I thought I'd get a leg up and try out Cura on my printrbot plus. So far so good! I like it!
It seems to always turn on my camera on my laptop, whether or not I have timelapse enabled, and also, I'd like to use a different camera (e.g one I can actually point at the printer) Is there an easy (or hard) way to do this?
Thanks!
-Kevin
    It's was a known bug that the camera gets turned on at start up, as a way to check if there is one present, and then under some (all?) circumstances it doesn't get turned off. But it was supposed to have been fixed I thought. Hopefully Daid, the developer of Cura, will respond here after the holidays.
    Don't know much about the external cam support - the webcam feature is a Windows only thing at this point, and I use a Mac.
    Ah, well, I figured out why the camera wasn't shutting off. I had apparently installed 13.06 a while ago. Even though I was running 13.12, it was picking up some components. I uninstalled, and now it shuts off properly.
    I'd still like to pick my camera.
    This is somewhere on my todo-list, but a bit far down. A work-around is to disable the laptop webcam in the device manager. Hardly ideal, I know.
          • Heart
        • 4 replies
