Posted · Colorfabb PA-CF Low Warp UMS3 CC0.6
Hello!
I'm trying to calibrate the flow since the default settings was over extruding.
I printed a 20mm test cube with only single walls with
layer thickness: 0,2
line width: 0,58
flow 100%
Measured the walls to 0,9mm and changed the flow to 64% and printed again.
Now it is under extruding with small holes here and there and not very good layer adhesion but still the walls are too thick, I measure them to 0,7mm.
What can I do to adjust this?
Jesper
