8 hours ago, GregValiant said:The best way to check is to adjust the flow during a print using the LCD control. Once you get it dialed in to an acceptable percentage then you can change all the flow settings in Cura to that number, and save it as your PETG profile.
II don't know if it's a slightly different diameter of filament, different coefficient of expansion, or what it is but there is an effect there that makes it different than PLA.
thank you for the reply. I read on the Cura settings support that "modifying the flow in order to solve the underextrusion, is not a definitely a solution". In any case, I would to print a single wall cube in order to understand if the flow is ok or not.
GregValiant 203
