GregValiant 1,330
In "Special Modes" you have "One at a time" selected. Change that to "All at Once".
If you use One at a Time, Cura checks the height of the model and if it is taller than the "gantry" height it won't slice it. Cura figures that the X beam will crash into a part. The blue rectangle about 25mm above the build plate is the clue.
1
Gaslov 0
In case you're curious, I'm printing it vertical likes this because I'm using a rainbow filament and want the color gradient in that direction.
Edited by GaslovLink to post
