100 micron shell with 300 micron infill/support
tharun
Posted · 100 micron shell with 300 micron infill/support
Hello im curious if this feature could be implemented into Ultimaker Cura, this could boost print quality and reduce printing time,
can cura have an experimental feature that can :
> print 2 or 3 layers of only shell (100 microns each)
> post which it prints one layer of infill/suport with 200 or 300 micron thickness repectively
    Let me see if I have this correct.
    You want to print 3 layers of the shell at .1mm layer height and then 1 layer of infill at .3mm layer height?
    Like this?...
    Quality / Layer Height = 0.1
    Infill / Infill Layer Thickness = 0.3.
    It would probably be a bad idea to add "Print Infill Before Walls".
