Cura won't run any longer in Windows 10
OneEffJeff
Posted · Cura won't run any longer in Windows 10
Yesterday, Cura ran fine, I run Versions 3.6 & 4.7. This morning, when I open the Cura window, all I get is a white screen with "Ultimate Cura" in the upper5 left hand corner of the screen. If I click the minimize page button and then click on the Cura icon in the Task Bar, Cura opens. The problem is, I have to minimize EVER time I do an operation to make it take effect. So to load a file, I click on the Folder icon at the top left, minimize the screen, restore the screen and then I get a list of files in my most recent folder. I click on the file, minimize the screen, restore the screen and my file is on the build plate. The settings table on the left can only accessed the same way but that works intermittently. HELP!!!!
I should mention that I reinstalled each version thinking they were corrupted somehow but I get the same result as I described above.
    Do you use multiple displays? If so, try disabling all but one of them temporarily. If Cura starts succesfully with a single monitor, go to the General preferences and uncheck the "Restore window position on start". Then you can re-enable the other screens, and Cura should always open on your primary screen.
    • 2 weeks later...
        • 9 replies
