Also, don't leave your machine hot when it's not printing..
When I'm starting up a print, I get EVERYTHING ready then start the preheat and start printing right away, once it gets to temperature. If you leave it hot when not printing, the heat will move up the hot end and encourage the plug that Daid mentions..
Daid 300
Your extruder is most likely fine. You'll most likely have a "plug" above the heater in the bowden tube. Which is blocking extrusion. At high heats this can happen.
Recommended:
-Check for a plug by removing the fan, removing the alu plate + everything below it (as 1 piece, taking these parts apart should be a last resort, as the brass and the PEEK break very quick). The plug should be in the tube.
-Print PLA no higher then 230C
-Watch out for temperatures nearing 300C, because your PEEK can melt then.
