Strange Cura UI issues in 13.12/10 under Mavericks
madoverlord
Posted · Strange Cura UI issues in 13.12/10 under Mavericks
I am running OS X Mavericks.
Cura 13.12 shows only Print speed under the Speed and Temperature part of Full Settings / Basic. I can't set the temperature. Also, I can't select objects once they are loaded.
I went back to 13.10; it lets me set temperature but popups like Platform Adhesion type are stuck and don't work.
I had to go all the way back to 13.06 in order to get a version where the UI worked for me.
Bizarre! Any suggestions?
    It's working pretty well for me on Mavericks. Do you have the printer configured as UM1 or UM2? You can't set temp for a UM2, for instance. I've had the platform adhesion popups be a bit non-responsive during a long slice operation, but once the slicing finishes they work again.
    Ah, well part 1 of the problem is fixed; somehow it decided I was using a UM2 instead of a UM1.
    Now the basic UI is working but I still can't select any objects on the printbed to move/rotate/resize them. All the other mouse actions (like changing the viewpoint) work fine.
